Do Not Sort Coded Value Domains Alphanumerically in Attribute Table Pull-Down Menus
1930
05-28-2021 01:00 PM
Status: Implemented
NathanHeickLACSD
I'm developing a file geodatabase schema and I noticed that my domains are sorted alphanumerically in the Attribute Table pull-down menus, but they are in my desired order in the Domains view.  Please do not force the order to be alphanumeric.
Tags (1)
4 Comments
NathanHeickLACSD
This also applies to the Select by Attributes command.  You are essentially making a decision that alphanumeric is better than what the database administrator set in the domain for the order of the coded values.  In addition, I seconded the ideas for providing more options to manipulate the domain order in the Domains view.
KoryKramer
This was noted as https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDA5ODIxMw== which is showing as fixed in ArcGIS Pro 2.9 - so updating this status to In Product Plan.
KoryKramer
For the comment about Select by Attributes - here is what I see in 2.7.3:
Here is what I see in a dev build of 2.9:
KoryKramer
As noted in previous comments, this was treated as a bug rather than an idea, which allowed for it to be addressed in a patch.  This is fixed in ArcGIS Pro 2.8 Patch 2 (2.8.2).
Select by Attributes:
