Do not replace existing values of indexed integer field with new OID values when converting a table to XY feature class
1055
08-13-2024 11:36 AM
Status: Closed
GaryBilotta
Please do not remove an indexed integer field and replace it with a new ObjectID field when converting a table of X/Y coordinates to a feature class.  In ArcPro 3.3.1, this is occurring and data is lost.  Thank you.
Tags (4)
2 Comments
TanuHoque
@GaryBilotta
Could you please reach out to Esri Support and have an support ticket opened for this? Did it work before?
KoryKramer
Status changed to: Closed
Hi @GaryBilotta If you are running a workflow where data is lost as you are describing, that should not be submitted as an idea. Please contact technical support to investigate. Thank you.
