In ArcGIS Pro we can add a toolbox to the project. However, the properties of the project toolboxes do not display the source location of the toolbox.
Please add "Source" to the properties of an ArcGIS Pro toolbox.
Thank You!
I don't really see a toolbox's location as a property of the toolbox. For example, I can take the same toolbox and move it around on my file system. Nothing has changed about the toolbox - it is just in a different location.
Catalog View displays the path for toolboxes added to the project:
You can also see a toolbox's path by hovering over it from Catalog pane:
Is there a particular reason you need the location to be in the toolbox properties, or do the two methods above work for what you need?
Hi @MarkVolz I wanted to check in on the Needs Clarification status/comment above.
Do the two options noted above work for you? If not, could you provide clarification so that we can have the geoprocessing team take a look?
Thank you!
Thank you for the confirmation, Mark. No need to apologize - I'm glad these options work for you!
