ArcGIS Pro 3.1.1
In the Catalog pane —> Database connection —> Properties —> Name:
The Name textbox appears to be an editable textbox.
However, in reality the textbox isn't editable.
Video:
That seems misleading.
Could that textbox be changed? For example, one of the following:
Edit: Regardless of what option Esri goes with, the text should still be copyable, since it's handy to copy the connection location.
I'm aware that I can rename the database connection directly in Catalog. That works. But I think the point is the properties Name textbox is somewhat unintuitive and could be improved.
Thanks.
Thanks for the idea @Bud I can see how this idea would improve the connection properties pane.
We'll take a look at it.
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
