Data Frame Rotation - Symbol and Annotation behavior
1172
03-17-2014 11:00 AM
Status: Already Offered
JaredCollier1
Using the ArcMap Advanced Settings Utility you can set marker symbols to rotate  with the dataframe or not.  You can also set label and other annotation behavior when data frame is rotated.  My idea is to incorporated this behavior into the core ArcMap settings and saved as part of the mxd.  I find myself switching these back and forth depending upon the project.
Tags (1)
1 Comment
WendyHarrison
This has been implemented in ArcGIS Pro.
Rotate point and polygon labels when map is rotated - located on map properties dialog.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/general-label-settings.htm
Rotate marker symbols with dataframe - located with the symbol properties under Angle Alignment
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/point-symbols.htm
