CTRL + double-click to refresh geodatabase in Catalog
1158
05-31-2024 10:34 AM
Status: Closed
Bud
Legendary Contributor
ArcGIS Pro 2.9.5
If I export features to a file geodatabase as a new FC, then I need to refresh the GDB in the Catalog pane in order to see the new FC.
I can refresh the GDB in Catalog via right-click > refresh. But it would be handy if I could do something like CTRL + double-click for an even faster way to refresh.
3 Comments
Bud
Never mind. F5 seems to work to refresh the geodatabase.
KoryKramer
Status changed to: Closed
Not "already offered" (i.e. ctrl + double-click doesn't do it) but I was going to suggest F5 which is even faster. Glad you found it.
SSWoodward
Thanks for the idea @Bud. You're correct that F5 will refresh the geodatabase by default.
Users are also able to define custom shortcuts using the shortcuts menu found in Help > Shortcuts or by hitting F12.
