Create new label classes with Arcpy
3320
10-31-2012 02:28 PM
Status: Implemented
GusMartinka
Add the ability to create a new label class to arcpy labelClass. Changing label classes is nice but creating new ones is needed.
3 Comments
ColinLang1
All they need to do is make sure arcpy.mapping.labelClasses can use the append() method for lists, and it's problem solved.  They had to have specifically removed this ability, as a list structure has it by default, so it's just a matter of removing the code that removed the ability.  I don't know why they ever took that out.  It's just not logical.
JeffBarrette
This will be available with Pro 3.3.
Layer.createLabelClass(name, expression, {sql_query}, {labelclass_language})
Jeff - arcpy.mp and Layout SDK teams
KoryKramer
This is implemented in ArcGIS Pro 3.3. See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
