Coordinate selection color in map and table for Pro
2901
11-19-2019 11:27 AM
Status: Implemented
JohannaKraus2
In ArcGIS Pro the user is able to change the selection color for all layers or an individual layer, but in the table the selection color remains the default cyan:
It should be the same just like in arcmap - or the user should be able to change the color of the table separately.
4 Comments
KoryKramer
I dug around a bit in ArcMap to understand the equivalency part of this.  By default, when I change the selection color for the layer (or set it for all layers under Selection Options...) I get something like this:
That seems to be similar in ArcGIS Pro:
ArcMap allows the user to set a different color to display selected records in the table, but it isn't necessarily coordinated with the map feature selection color:
So this part
is specifically the ArcMap equivalency part, but I'm wondering, do you often set these differently, or would it be easier to just check a box to sync map selection and table selection color?  I actually found it a bit niggly to remember exactly which color I had chosen for the map selection and it would have been way easier to not have had to specifically find that and choose it again
JohannaKraus2
This is a good question and I had to go back to arcmap to see exactly how it worked (yes, I realize I just did it yesterday!) and it isn't real logical.  It would be nice in Pro to have an opportunity to set selection for the map and the table at the project level and also for each layer or table in the TOC.  Personally I would probably sync the two (and an option for that would be nice), but I think it's also possible someone would want the selection colors different.
Something like this:
Does that help?
AlyciaRajendran_esri
Yeah the dev team definitely agrees with this. This is in the product plan for 3.2. Thanks!
KoryKramer
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
