Catalog-Dataset: Draw Selected Order
800
08-21-2025 01:22 AM
Status: Open
JuliaThomas
Since the raster catalogs are no longer available, we now use a catalog dataset to store our georeferenced raster files in the SDE. However, ArcGIS Pro lacks a feature that was available in ArcMap for raster catalogs: drawing rasters when a feature is selected (Draw Selected Order). This feature could be checked in the layer properties under the "Selection" tab (Picture).
Since we work with multiple contents in the catalog dataset that overlap in places, it is not sufficient to set the layer limit to 1, for example, to display the desired raster. It would be desirable to be able to select an explicit feature in the attribute table again, which would then be drawn.
2 Comments
TanuHoque
hi @JuliaThomas
you are right that catalog dataset/layer in ArcGIS Pro is the replacement of raster-catalog layer from ArcMap.
Thanks for sharing this idea. Would you mind share a few more screenshots? Or it would be even better if you could record your workflow and share that here as an animated gif or some video? That would be very helpful.
Thank you!
Tanu
JuliaThomas
Hey @TanuHoque,
here you can find the video about the settings.
By activating “Draw raster”/"Raster zeichnen"  the raster content that I selected in the attribute table is displayed exactly.
Thank you!
Julia
