Bring back shape field visible fix when publishing services
2022
04-02-2024 06:36 AM
Status: Implemented
MelanieWawryk
Please bring the fix to the shape field not being visible when publishing a service that you had in ArcMap to Pro. Now we only have Select Layer in TOC and then have to open each table, then open field view to turn the shape field on, then save and close the field view. That is a lot of unnecessary steps for something that would have taken a second to fix in ArcMap.
Someone must have a python script to do it but this is a clear oversight when they were building Pro.
Tags (1)
4 Comments
Brian_McLeer
JonahLay
JonahLay
SusanTran
In Pro 3.5, there is an analyzer solution "Open Fields View" available when you right-click on the analyzer in the sharing pane.
