Automate close panes in ArcGIS Pro tasks
5074
11
11-08-2018 08:27 AM
Status: Implemented
JoeGreene
When building steps in a task workbook, it would be nice to automate closing panes that are launched in previous steps. Many tools can be embedded in the task pane but the space in this pane is limited and some tools are confined even further into a small window with scroll bars within the pane. If you don't #embed them, the only way to close the pane is to create a step that tells the user to manually close it. This would prevent the project from getting cluttered with panes that were only used once in the task workflow, reduce clicks for the user and reduce the number of steps in a task.
11 Comments
KoryKramer
JoeGreene
They are related but not the same. It is asking about controlling views (map/scene or layout). This idea is talking about closing panes as they open when tasks are run.
AmirBar-Maor
Tasks restore panes to their saved state once the step proceeds:
If the pane was closed tasks closes the pane after the step.
If the pane was minimized tasks minimizes it after the step.
Tasks do not control map view configuration (side by side for example) today but we do plan to support it in the future.
AmirBar-Maor
When a task step opens a view from a closed or minimized state it will return that pane to the original state when it moves to the next step.
Views (e.g. map view, layout view, catalog view,  attribute table view...), as well as other controls, are not included.
If you see a different behavior with panes please report a bug.
Many panes can be embedded in the task itself which reduces the "pane clutter".
SarahSibbett
@AmirBar-Maor - your comment here "Tasks restore panes to their saved state once the step proceeds"
Are you saying that if I click 'Run' in a task step and it opens the 'Align Parcels' pane, when I am done with my alignment and I click 'next' in the task, the Align Parcels pane should close? This is not the behaviour we are seeing...would you expect something different?
I know we could embed the Align Parcels pane into the task, but the view gets really small (as the original poster mentioned). So we pop it out into a new pane. When we are done and click next in the task, it would be ideal for the align parcels pane to close, since it does filter selections (and sometimes the mappers forget the window is open).
AmirBar-Maor
@SarahSibbett
It looks like we have a regression with all of the Editing Modify panes, This includes the Align Parcels pane which is part of the modify tools.
Thanks for reporting
SarahSibbett
@AmirBar-Maor - thanks for confirming. Do you want me to log a bug through support? Is that the best course of action?
AmirBar-Maor
@SarahSibbett
Logging a case with technical support is always recommended.
Thank you
SarahSibbett
@AmirBar-Maor - sounds good. Just logged one through Esri Canada support and will post the BUG number here once I have it. Appreciate the feedback!
AmirBar-Maor
