ArcReader: Export more options; no white space
882
11-02-2011 09:42 AM
Status: Closed
CraigEissler
1. Export option is limited to BMP. This should be expanded to at least include PDF and either JPG/GIF/PNG, or perhaps all the options in ArcGIS.
2. Inserting the current exported graphic (BMP) into another application like PPT or WORD includes "white space" around the map. This then does not allow you to expand the map graphic to the full size of the page, which can be a hindrance in presenting and/or seeing necessary detail more clearly.
Tags (1)
2 Comments
ChrisMathers
You need to edit the layout of the MXD before you publish it to PMF for use in ArcReader. The BMP exported should look exactly like the layout. Speak with the person providing the PMF about layout changes.
CraigWilliams
Status changed to: Closed
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap to ArcGIS Pro for more information. Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
