arcpy.mp open mapx map files and pagx layout files
3838
05-20-2016 05:48 AM
Status: Closed
AlexanderGray
Honored Contributor
Arcpy.mp allows you to open project and layer files.  The GUI allow you to save maps and layouts and layer files.  We need to be able to open map and layer files in arcpy.mp to modify the update connection properties and other properties before loading the in the project.  Having all the possible maps and layouts a users would want to use in a project is not practical if it numbers in the dozens and only a few are used at the time.  This way you can build a library of mapx and pagx files to use in your projects.
4 Comments
JeffBarrette
Does ArcGISProject.ImportDocument() satisfy your needs?  It allows you to import mapx, pagx and more into a project?  We also support exporting to these formats.
Or do you want to be able to connect to a pagx or mapx and repair datasources directly on those?  A work around would be to importDocument into a project, change datasources and then export back to the appropriate X file.
Jeff - arcpy.mp and Layout teams.
JeffBarrette
Status changed to: Closed
Given you can use importDocument(path to mapx), change data sources, then export back to mapx, this lessens the priority of creating additional classes and members given a fair amount of other planned development work.
If the above workflow does NOT work for you, please describe in detail you scenario and we could reconsider.
Jeff - Layout and arcpy.mp teams
matt_g_g
It would be great to get direct interaction with a mapx or pagx file implemented. I know it can be done via import into a project but in many cases the overhead of a project isn't required.
JeffBarrette
Thanks @matt_g_g . If you write your script to work out of process along with a reference to a "blank.aprx", for example, it all would happen in memory and the application would not even be opened.  To work with a mapx or a pagx file, you need the application (internal logic) to read the files in order for them to be modified.  Even if you wanted to use Python CIM access to modify the JSON structure, you still need the application.  Those X files are text files but I would never recommend modifying those in a text editor.  If you have specific issues with import/export x-files, I'd like to know the limitations.
Jeff - arcpy.mp and Layout SDK teams
