Arcpy: Enable Time on tables
2394
10-19-2017 11:45 PM
Status: Implemented
Ceesvan_Altena
Hello,
With Arcpy it is possible to enable Time on a MXD's feature layers. This can be done with the 'UpdateLayerTime' utility from the 'arcpy.mapping'. We also want this utility for tables! After support from Esri, it is confirmed that it is not possible to enable Time on a MXD's tables.
Some extra info, when you put a MXD's table in the UpdateLayerTime utility you get an error.
We would like to get the feature to enable Time on tables with Arcpy.
With kind regards,
Cees van Altena
Tags (1)
4 Comments
KoryKramer
ceesvana
Can you describe how you use a standalone table in a time-enabled map?  This might help understand why this functionality is needed.
Thank you.
JeffBarrette
This won't be addressed for arcpy.mapping (ArcMap) but we do plan to add it to arcpy.mp (Pro). Time for stand-alone tables was just made available at 3.0.  We hope to make it available in the near term.  Adding members similar to Layer like isTimeEnabled and enableTime() makes good sense.
Jeff - arcpy.mp and Layout teams.
JeffBarrette
This is planned for ArcGIS Pro 3.3.
Jeff - Layout SDK and arcpy.mp teams
KoryKramer
This is implemented in ArcGIS Pro 3.3. See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
