ArcMap share service wizard removes layer without warning
1228
04-27-2016 10:34 AM
Status: Closed
mattwilkie
When sharing a service with ArcGIS Online double clicking wizard “Warning 24041 – Layer does not have a feature template set” removes the layer from the map instead of going to feature template settings. If the user doesn’t notice this and saves and closese the map, prior work is gone.
To replicate: ArcMap >> File >> Share as >> Service >> Publish >> My Hosted Service >> Capabilities:
Tile Mapping: No
Feature Access: Yes {Check All}
… >> Analyze: then double click “Warning 24041" >> removes the layer from the map
Double-clicking the warning will invoke its assigned action which in this case is to remove the layer from the data frame. You can see this assigned action by right-clicking the warning. If you did remove the layer by mistake you can undo the action by clicking on the Undo function in the Edit menu.
2 Comments
mattwilkie
Forgot the screen shots and to reference the Tech Support incident this started with, "Esri Case #01773088 - ArcMap share service wizard removes layer"
0EME0000000Y2A1
0EME0000000Y2A6
KoryKramer
Status changed to: Closed
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap to ArcGIS Pro for more information. Thank you for taking the time to share your ideas.  We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
