ArcGIS Pro Visibility Range control
5241
05-04-2018 02:43 PM
Status: Implemented
geodoozer
Proposal:
I suggest tweaking the Visibility Range control to be more intuitive e.g.
Justification:
The visibility range control in ArcMap is Don't show layer when zoomed.
ArcMap visibility range control
In Pro, the control functions the same way, but Don't is missing, meaning the control may be interpretted as Show my layer when the scale is zoomed in or out beyond...
Visiblity Range control
This may be confusing for users unfamiliar with ArcMap, but also cause ArcMap users puzzlement as they initially wonder if the control works the same or differently.
5 Comments
CherylTrine
I just spent fifteen minutes playing with this trying to figure out what was going on.  It was only when I went to layer properties did I figure out what was up.  Visability Range under the Appearance tab needs additional/different verbage, because otherwise it is implied that if there is a value in "In Beyond" the layer should be visible in beyond whatever value is input.
KoryKramer
The layer properties windows provide an equivalent message between ArcMap and ArcGIS Pro:
There are hover tips in the UI that provide a good explanation about what each means:
I see your point about moving that explanation out from behind a hover tip, though.
KoryKramer
KoryKramer
This is implemented in ArcGIS Pro 3.3. See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
geodoozer
Wow!  That is so cool, thanks!
