ArcGIS Pro - Set as Startup Project Function
766
06-29-2019 02:38 PM
Status: Open
DavidHowes
Situation
ArcGIS Pro allows the user to set the default project to be opened on startup by specifying a path in
   Options/Application/General/Start ArcGIS Pro/With a default project
Suggestion
Add a shortcut on the Open/Recent projects list to specify the default project:
  • Under Project/Open, for each item the in the Recent Projects list, provide a second context menu item "Set as Startup Project"
  • On click, set the default project value in Options/Application/General/Start ArcGIS Pro using the selected path
Thanks.
