ArcGIS Pro Pop Up column width not adjustable
6452
14
02-12-2020 08:46 AM
Status: Implemented
PamelaBerry
Our team uses the Identify or Explore pane to view data from one feature while editing another feature. We keep it open and docked on the map. We are updating building structures and giving them attirbutes for use discription. Before the update, the columns in the pane could be adjusted to fit the window and the use field selected to see at a quick glance what it was described as. The fields in the pane are no longer selectable and the columns are not adjustable. Just wondering if this functionality can be restored.
14 Comments
PamelaBerry
Thank you for commenting. I think our issues are the same. I hope they can restore this functionality.
GISOfficer
It would be great if this can be fixed in the next release, otherwise when undocked one has to make the popup overly wide in order to see data.
KoryKramer
Column width in pop-ups will be adjustable in ArcGIS Pro 3.5 (planned for late April/early May 2025).
ValeriaChavez
Hi @PamelaBerry! This Idea was implemented with the ArcGIS Pro 3.5 release. You can learn more about this on the Attribute Display section of the Pop-ups documentation. To see what else is new in the world of ArcGIS Pro pop-ups, checkout the What's new in ArcGIS Pro 3.5 documentation and the Your Ideas in ArcGIS Pro 3.5 blog on Esri Community.
