ArcGIS Pro- Option for Default ArcGIS Pro Basemap (Independent of AGOL Setting)
4533
8
08-17-2021 12:47 PM
Status: Open
Amanda__Huber
MVP Regular Contributor
Hello ArcGIS Pro Team,
Our organization is looking to set our default ArcGIS Pro basemap to be different than our default ArcGIS Online basemap.
Our current basemap in in WGS 1984 which is great for the web, but not so great when it comes to measuring or analyzing our UTM15N data. Since ArcGIS Pro's map frames take the projection/coordinate system of the first layer added to the map (basemap) the rest of the data added later is re-projected on the fly. Since this basemap is a default, our users (wide variety of departments) don't always think of this, and it can lead to incorrect measurements/ accuracy issues.
We currently have a basemap in UTM 15N, but don't want to make this the ArcGIS Online default. We're looking to set the ArcGIS Pro default to be independent of the ArcGIS Online default.
Please consider this, we would be happy to talk about this more over a call as well.
Thank you,
Amanda Huber
Three Rivers Park District
8 Comments
RichardDaniels
Suggest you look into the .mapx format. It provided a way to import Map Templates (in our case containing our agencies standard base map) that is independent of Project files or ArcGIS Online organization membership.
Save a map file—ArcGIS Pro | Documentation
In our case we have a custom Ribbon for Pro with a tool that loads our .mapx if no Maps exist in the project OR if the user selects the 'Add Standard Map' option in our ribbon.
jcarlson
You can tell Pro you'd like a different default basemap in new maps and scenes in Options → Application → Map and Scene.
This requires the selected map to be in the org's basemap gallery, but that's as simple as sharing a map from Pro to your basemaps group.
RichardDaniels
In Pro at this same location
you can set a default spatial reference that will over ride the 'use spatial reference of first operational layer' default.
Amanda__Huber
Thank you all for the speedy replies!
@jcarlson @RichardDaniels is there a way to set this up in the deployment though? (global setting) Otherwise we'll have to modify every single person's PC and upgrades will probably affect this setting.
KoryKramer
Thank you for submitting this @Amanda__Huber !  We need to run through some questions to make sure we understand the issue, though.
This shouldn't be the case.  Looking at the help for Map and scene options https://pro.arcgis.com/en/pro-app/latest/help/mapping/properties/default-settings-for-new-maps-and-s... It should be the first layer added that is not a basemap will set the map's spatial reference:
In this example, I added a new Map to my project and it's spatial reference was WGS 84 Web Mercator Auxiliary Sphere.  Once I added an operational layer (Roads) I see that my map's spatial reference is now NAD 1983 UTM Zone 12N:
There is another option to 'Choose spatial reference' so you could set that but if all of your data is in UTM 15N then maps's spatial reference should be set to that when operational layers are added.
Is that not what you're seeing?
KoryKramer
@Amanda__Huber just saw your further response and question.  See https://community.esri.com/t5/arcgis-pro-ideas/migrating-arcgis-pro-options-settings/idc-p/1015675/h... Basically there is now a framework in place, but we need to prioritize which Options get added.
Based on this idea, your organization wants to control the Basemap and Spatial Reference settings in the Map and Scene options, correct?
KoryKramer
Status changed to: Open
Re-opening this now that it is clear from the comments that much of this is possible but the request is for a way to deploy the option set in a certain way to multiple users in an organization:
From Amanda: "a way to set this up in the deployment though? (global setting) Otherwise we'll have to modify every single person's PC and upgrades will probably affect this setting."
ThomasUhrePedersen
Hi Amanda
I believe it is possible to have multible in the current version of ArcGIS Pro (3.6 and earlier)
By now you can control the default basemap or spatial reference in use by Pro by the Pro.settingsconfig file.
On each individual PC you can point to different Pro.settingsconfig files using HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro\Settings
Further reading:
Manage application settings—ArcGIS Pro | Documentation
Map and Scene settings—ArcGIS Pro | Documentation (look for DefaultBasemapJson or DefaultSpatialReference)
