ArcGIS Pro: Dynamic images from hosted feature services
848
02-06-2017 04:18 AM
Status: Under Consideration
PhilipGlasner1
I have the workflow to create a report for each feature that is collected with Collector for ArcGIS. For each feature several photos are attached. The report is created in ArcGIS Pro using map series. The collected photos are placed on the layout and are dynamic for each feature. Unfortunately, ArcGIS Pro cannot reference the attachments dynamically from the hosted feature service. First, the features need to be downloaded from ArcGIS Online and then integrated into ArcGIS Pro. It would be great if the attachments of the hosted feature service could be referenced directly withouth the need to download the features first.
3 Comments
SaschaEsser
To add an attachment to a layout, you must define a Map Series. Regardless if there is a Map Series or just a single map, this is not very intuitive. My suggestion is to have an element in the "graphics and text" section to add an attachment for a 'Single Map'.
AubriKinghorn
AubriKinghorn
