ArcGIS PRO Cursor Identify tolerance
9650
16
09-05-2019 08:02 AM
Status: Implemented
RobertGraham
When selecting points you must be exactly on top of feature to identify.  The point tolerance is not adjustable for identify.  The snapping tolerances are adjustable but not the identify feature from the Explore tool.  Please make the Explore tool tolerance adjustable.
This is reported at version 2.3.2
16 Comments
KoryKramer
KoryKramer
This is implemented in ArcGIS Pro 3.3. See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
JulioGarrido
All,
I have verified this implementation.  We can now change the selection tolerance of the Explore/Identify tool.  It can be changed through Project - Options - Selection.  Scroll down to the bottom of the selection options and place a check next to Buffer the clicked location to include features within xy pixels. (change xy to your desired value).
CharlesFinley2
i am so glad this has been implemented, thanks ESRI!!
KoryKramer
Glad it helps @CharlesFinley2 !
JulianWard1
Hi @KoryKramer ,
This is a great implementation and solved a problem for me, however I think I just found a flaw / bug in it.  It doesn't seem to be honoured when sourcing the data from a web service.  While I can click 'off from' a point using a direct connection to a featureclass and still have it returned, I can't do the same on the same dataset sourced through a ESRI REST endpoint (MapService).  Whilst a MapService has a 'Tolerance' parameter that I assumed the buffer would use, I find myself having to still click exactly on the feature to have it return the identify result.
I'll submit this as a support / bug request, but it may be something that needs looking into as sourcing data from web services becomes more prominent,
Cheers
