ArcGIS Pro 2.4.2: “view cache status” tool is not available,
10277
23
10-21-2019 12:33 PM
Status: Open
JamalNUMAN
Legendary Contributor
It would be great if the “view cache status” tool gets available in ArcGIS Pro
23 Comments
KoryKramer
Are you referring to being able to see the status while caching is in progress?
Sharing job status—ArcGIS Pro | ArcGIS Desktop
JamalNUMAN
What I meant is the information below
MajdoleenO_A__Awadallah
How to view the cache status for a cached service using Arcgis pro,
We couldn’t figure out where is the cache status on the Arcgis pro, otherwise, we can find it on Arcmap by clicking right click on the service. Is this available in Arcgis pro?
Aled_Jones
As a workaround:
Head to your cached service within the cache directory
i.e. *ArcGIS Server Dir*\directories\arcgiscache\*name of cached service*\Layers
Open the layers folder
Copy status.gdb to a accessible location for ArcGIS Pro. Ideally a folder that you already have a folder connection to (ArcMap/ArcGIS Pro will interpret the Layers folder above as a raster, you can't 'dig' into this)
Open status.gdb using the catalogue pane.
Drag CacheStatus into the TOC.
Open attributetable.
View cache status.
Thank you Aled, it is very nice workaround, it works fine! but the old approach of Arcmap is much better, I highly appreciate if esri team consider this in the coming release.
RandyKreuziger1
The person building the cache may not have access to the ArcGIS Server so this workaround is very limited.
JamalNUMAN
This appears not to be available in 2.5
JamalNUMAN
Is this planned for 2.6?
JamalNUMAN
is this planned for 2.7?
MarkChilcott
Being able to view the cache status is a critical part of our workflow.
This functionality needs to be part of Pro.
