Allow Table Statistic Dynamic Text on Date Fields
1508
08-23-2023 07:56 AM
Status: Open
ChelseaRozek
MVP Regular Contributor
The dynamic text documentation for layouts in Pro says that "other statistics can only be run on numeric fields" so my date fields are not showing up when I want to insert such statistics as range, maximum, or minimum. At least for these basic statistics, it doesn't seem like an unreasonable request for a date field. It would be great to be able to show the range of project dates in the current map extent.
Tags (3)
3 Comments
AubriOtis
Date fields and number fields are a little different, which is why those statistics don't currently work. However, we have time dynamic text options that might work for you. Will these provide what you need or are there additional elements missing?
Cheers,
Aubri
ChelseaRozek
Hi @AubriOtis , I'm hoping the offerings can be improved upon. That screenshot does not help me because it's the map frame's start/end times and not the values from my point feature class. I'm not working with the layer time enabled so there are no values for me (see below).
AubriOtis
Status changed to: Open
Thanks for the clarification, that's good information to know.
