Allow layer files to be elevation sources
4242
11-17-2020 09:25 AM
Status: Implemented
MichaelSmith1
I support about 20 ArcGIS Pro users. I try to keep it simple for them by using layer files in a network folder which point to the various data they typically use. Thus they don't have to go to a database connection for our enterprise data, server connections for stuff we publish via image services, etc. This includes having layer files for elevation data that is stored elsewhere. However in ArcGIS Pro, using local or global scene, layer files are not supported for elevation sources. I would like the 'Add Elevation Source' dialog to support layer files.
4 Comments
Andrew--Johnson
Thank you for submitting this idea. I will post back here after we have discussed this further.
Andrew--Johnson
This has moved into product plan for the ArcGIS Pro 2.8 release.
MichaelSmith1
That's great. Thanks Andrew.
Andrew--Johnson
Implemented in ArcGIS Pro 2.8
