Allow changes to default decimal places
2036
6
09-26-2023 08:37 PM
Status: Open
AvaFarouche
Hi! In Pro, default decimal displays for all labels and legends are anywhere between 6 and 15 decimal places, and the only way to change these is to manually change each individual attribute for each layer.  I recently had a map project that required me to change the display of decimal places 900 times. NINE HUNDRED!!!
What made this especially frustrating is that the underlying data tables only had two decimal places. So Pro added either 4 decimal places for all legends, or between 10 and 13 decimal places for labels. It just fabricated those numbers, and I had to manually change all of them back to something manageable.
I figured out that the best way to do this is to go into the attribute table and edit each attribute to a Double Numeric designation and specify 1 or 2 decimal places. If I don't, when I publish it to Web map, all of the decimal places will display as 6 places AGAIN. But even when I do that, I still have to do it AGAIN for legends in desktop, because those still default to 6 decimal places. I can't wrap my head around why the default would be for so many decimal places to display, or why I would have to change each attribute in each layer, instead of being able to change a default setting somewhere. It seems like that many decimal places would make just about any project messy, cluttered and confusing.  Space is usually very tight in my maps. There can be loads of labels, and it's challenging to fit them all in anyway. I can't allow any unnecessary content in either my labels or legends so I can't just leave them.
Thank you very much!!!
6 Comments
JoyDRoberts
Agreed that having a 6-decimal place default for all numeric fields is not logical and is counter-productive for users.
We're not measuring things to millionths of a unit. IF the numeric field happens to contain coordinates, then the (excessive) "accuracy" is only applicable to latitude/longitude pairs. It's surely not best practice for the measurements in the projected coordinate systems.
PLEASE FIX THIS, Esri team.
Thank you for listening to us.
DavidOutrata
It is hidden under Advanced symbology options:
JoyDRoberts
@DavidOutrata - That might fix the issue for some users, but doesn't resolve the underlying data issue as posted by Ava and myself.
Thanks for posting it.
AvaFarouche
Yes, @DavidOutrata , as I indicated in my original post, I found the way to fix it in the Advanced Symbology. However, the problem remains: I have to fix it there for every attribute, for every layer, which means, as I indicated in my original post, I had to change it NINE HUNDRED TIMES. This does not address the problem. Thanks.
LisaPierce1
Decimal default settings needs to be an option to change for your entire Project settings, not just for a layer.  The comments above describe the issues and seems rather strange that ESRI felt the 6 decimal places was logical?
What is the best way agencies can set default settings for many options that can be defined across your organization for ArcPro deployment?
I believe that may be expressed in templates in Pro. More documentation on this topic would be helpful.
ZachEdwards_WDSGIS
Agreed. There needs to be a place where we can set the default Numeric (number of decimal places in the precision) just like you can set your default display location units precision for lat/long/elevation!
