Currently, in ArcGIS Pro, the Arcade Labeling profile is restricted to only accessing attributes from the specific layer being labeled (using $feature.fieldname). I am requesting that the Labeling profile be expanded to support cross-layer attribute referencing (for example, by allowing functions like FeatureSetByName or a similar optimized method), just like how it currently works in the Pop-up profile.
I can't speak for ESRI with authority, but I'm pretty sure I remember seeing posts by ESRI Staff clarifying that they explicitly disallowed the FeatureSetBy[...] functions in Symbology and Labeling allegedly for performance & database call reasons.
It would definitely be nice, though, so I'll toss this a Kudo in case I'm wrong and/or the policy ever changes.
Here's some additional info/context to the rationale for not including feature set functions in visualization and labeling profiles: https://developers.arcgis.com/arcade/function-reference/bundles/#data-access
