Add timestamps to Arc-Map Startup Logs
694
06-24-2019 07:13 AM
Status: Closed
by Anonymous User
Not applicable
Hi Esri,
The following article explains how you can generate ArcMap start-up logs:
https://support.esri.com/en/technical-article/000009316
We would like to add timestamps to the log-file now in order to have an idea about the duration of each step during start-up.
1 Comment
KoryKramer
Status changed to: Closed
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap to ArcGIS Pro for more information. Thank you for taking the time to share your ideas.  We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
