Add the ability to pin often used label class settings
562
09-28-2025 07:25 PM
Status: Open
RTPL_AU
I have a few settings in the label settings pane that I use 99% of the time.
Please add the ability to pin these sections open so that I don't have to open them every time I want to change a setting in the section.
In this example, Appearance, Halo, and Callout are frequently used.  Under Position> Fitting Strategy,  I always go to Overrun & Reduce Size
Having these often used areas open when the tool loads will significantly reduce the number of mouse clicks I have to make daily.
1 Comment
WendyHarrison
Presently there is not a way to pin the expanders open.  You can hold ctrl + click on an expander to open/close all of the groups. This may help for now.
