Add property to table objects determining if they are a view or not
896
05-20-2025 06:30 AM
Status: Open
AlfredBaldenweck
MVP Frequent Contributor
Related: How to Determine if the item in geodatabase is a view or not?
Related Idea: Catalog: Add view icon
There is no way in arcpy to determine if an object is a view or a real table, or, for that matter, no easy way period to tell if an object is a view or not, even in Catalog.
Adding an isView() property would make things very easy; we would not have to resort to checking if the table is editable (error-prone) or using a naming convention ("recent_nests_VIEW") to verify our inventory of tables.
Please add some sort of property to Describe to let us do this.
1 Comment
HaydenWelch
Huh, I've never really used views and usually just use layer definition queries. Seems like a useful feature if it was made clear that a view is defined by a query. The view definition is even transparent to da.Describe. It lists the View as a `DEFeatureClass` and not a
You can see that a featureclass is a view if you open the properties, but that means there is an internal API that can tell that it's a view.
To add to this proposal, there should be a subtype of `DEFeatureClass`/`DETable` called `DEFeatureView`/`DETableView` or something similar. These types should have a definition property that clarifies the type.
Changes to arcpy/typing/describe/base.pyi:
class Table(TableBase, EditorTracking): ...
class FeatureClass(FeatureClassBase, EditorTracking): ...
+ class TableView(Table):
+     @property
+     def definition(self) -> str:
+         """The SQL Definition of the TableView"""
+ class FeatureClassView(FeatureClass):
+     @property
+         """The SQL Definition of the FeatureClassView"""
Changes to /arcpy/typing/describe/__init__.py
DescribeDataTypes: TypeAlias = Literal[
     "VPFTable",
     "Workspace",
+    "TableView",
+    "FeatureClassView",
Because the code that interfaces with the View is not part of the public API currently, just adding this here and still treating the View as a `DEFeatureClass`/`DETable` internally should be very backwards compatible while allowing developers to quickly retrieve the View definitions. Because the View definition isn't editable anyways, keeping the definition property R/O is fine, this will just allow tools that pull an old definition, update the query, and replace the View with a new View.
