Add multipoint feature class support for Create Points Along Line editing tool
1226
05-19-2022 04:09 AM
Status: Under Consideration
hone888
Testing the feature...... but the Points Along Line tool doesn't appear on my multipoint layer, only the multipoint tool is available.
Any tips thanks!
2 Comments
JMutunga
@hone888 The workflow you pointed out is not supported at the moment.
I'd suggest you try the Offset tool.
In screenshot below, a Multipoint feature class was used as a template and a line feature selected along which the points would be created. Offset value was set at 0 so that points would be created exactly on top of the line feature.
I hope this helps.
Scott_Harris
