Add Layer from Web Option in ArcGIS Pro
2557
04-13-2016 01:09 AM
Status: Closed
MichaelKelly
With ArcGIS Online, you have the ability to 'Add Layer from Web' as in the screenshot below:
0EME0000000Y0Nc
This is a very easy way of adding a wide variety of services to your map. In ArcGIS Pro there is no equivilant functionality. You have the option to add layers to a webmap and sync with an ArcGIS Pro map, or search for services registered with a portal but this isn't wuite as flexibe - you have to either register the services in your portal or add them via a webmap.
If something similar could be added to ArcGIS Pro it would be very useful.
3 Comments
MichaelKelly
This was added with the last release (Data From Path):
Data From Path
Adam-Glover
Winner!!!
CraigWilliams
Status changed to: Closed
As noted, this was implemented with Add Data From Path
