Add field view to TOC right-click list. There are way too many steps to turn on a field in Pro. Please add the Field View to the TOC. I shouldn't have to open the table view and then select Field View to turn fields on and off, let us go directly to the field view from the TOC
From the Contents pane, right-click on the layer and choose Data Design > Fields view.
You can also click Data Design and hit F (the underlined key in the menu) to open Fields view.
That is much better, thank you!
