Please enhance the "Publish Web Layer" and "Overwrite Web Layer" tools in Pro so that they check that all layers & standalone tables in the service that have Editor Tracking Enabled use the same "Time standard" option.
I have found that if one layer has "database time" and a second has UTC time, then the tool will allow the service to publish, but it will be corrupt. According to the documentation all layers in a service with Editor Tracking must use the dame Time standard option. I encounter this in ArcGIS Enterprise 11.5, Pro 3.5 when publishing a feature service referencing an enterprise geodatabase.
In my situation the difference was an oversite when setting up editor tracking when adding some layers to a service. It would be helpful if the tool checked for this, informed the user, and prevented publishing.
Hi @AndrewRudin1,
Thanks for your submission. This is a known issue that will be addressed in an upcoming release.
Best,
Jonah
This idea has been implemented in ArcGIS Pro 3.7. Analyzer error 00439 was added to address this scenario of mixed editor tracking time zones.
Please see What's New in ArcGIS Pro 3.7 to learn about other new updates.
