Add Advanced ArcMap Settings to Tools Menu in ArcMap
1486
06-13-2010 11:52 AM
Status: Closed
ChrisSergent1
Whenever you try out an extension; it usually ends after 30 days or something like that and then a warning is received that displays to run ArcMap Advanced Settings. I usually have to search for .exe. It would be helpful if a menu item was added to to the tools menu to run this or possibly add a link in the message box to open ArcMap Advanced Settings.
Even better: let the message box display; Warnings are on. Would you like to turn them off?
Click yes or no and then get gack to work.
1 Comment
CraigWilliams
Status changed to: Closed
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap to ArcGIS Pro for more information. Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
