Add a calculated field to feature class
1633
06-19-2013 02:54 AM
Status: Already Offered
YMahdy
In Access 2007 & 2010, you can create table fields that calculate values.
It will be great if we can have same in ArcGIS database, to create field with data type "Calculated" from other existing field and functions.
This field should automatically updated based on the precedents fields
Regards,
Yasser
3 Comments
RonnieRichards
This is a great idea! The closest thing to it is the attribute assistant add-in. However this only works on desktop and the web editing environments. Also managing the desktop add-in and Mxd's for 50+ workstations is not  the easiest administration, storing this in the geodataase as a data type makes sense.
AZendel
Yes, please!  QGIS has this......
DrewFlater
ArcGIS Pro's Calculate Field tool supports adding a new field to calculate values into.
