Ablility to change ArcCatalog font size
1864
05-11-2015 09:06 AM
Status: Closed
BrooksWilson
It would be nice to be able to change the standard font size in ArcCatalog. I think it would be an option under the ArcCatalog Options menu and would increase the size of the text in the folder directory and catalog tree.
2 Comments
RobertBorchert
You can change the font and font size in ArcCatalog under Customize.
However, as you ask it will not change the font in the directory tree.  That is a system setting on your computer and by defuat is dependent on your resolution setting.
If you click on search files and programs for
Font Size
Control Panel\Appearance and Personalization\Display
should open up.  Here you can increase your font size but it will increast it for everything.
CraigWilliams
Status changed to: Closed
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap to ArcGIS Pro for more information. Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
