Ability to Set Minimum and Maximum Zoom Levels and/or Geographic Extent for Web Maps.
856
05-15-2025 08:21 AM
Status: Closed
Debert
Please consider providing the ability to set minimum and maximum zoom levels and/or geographic extent for Web Maps, either in ArcGIS Pro, AGOL, or Field Maps.
Within Desktop Pro, you can set custom zoom extents by defining a minimum and maximum scale. However, to achieve this, you must also set intermediate zoom scales between the minimum and maximum. I attempted to add 20 custom zoom extents, and after publishing, panning and zooming the map became jumpy and glitchy. Instead of a smooth, fluid motion, the map jumped from one zoom scale to another.
Simply being able to set the minimum or maximum zoom extent for a Web Map would be very helpful.
I've logged ENH-00129220. I hope you'll consider this.
1 Comment
ValeriaChavez
Status changed to: Closed
Hi @Debert,
Thank you for submitting this Idea. The ability to enforce minimum and maximum zoom levels for layers is an Idea better suited for the ArcGIS Online and/or ArcGIS Enterprise teams. To ensure this gets in front of the right folks, please submit to the corresponding Ideas board instead:
 Thank you for being an active member of Esri Community!
