Virtualization of ArcGIS Pro White Paper
3227
02-02-2016 01:32 PM
An Esri white paper on virtualizing ArcGIS Pro.  If your organization uses virtualized desktops for delivering GIS software to end users, and you are using or plan to use ArcGIS Pro, then this is a must read white paper.
ArcGIS Pro works great in virtualized desktop environments and a virtual environment is a scalable, enterprise option that can provide a great user experience with less cost.  An important note is ArcGIS Pro has different hardware requirements than ArcMap in order to deliver the same experience as a local desktop machine.  Esri has tested virtualization hardware for the best performance of ArcGIS Pro and has partnered with multiple vendors in order to offer the right specifications for you.  Esri has also partnered in the creation of an all-in-one virtualization appliance for easy deployment.
Version history
Last update:
‎02-02-2016 01:32 PM
Updated by:
Contributors
