ArcGIS Pro 3.3 Patch 2 (3.3.2) is Now Available
8179
09-19-2024 11:06 AM
The ArcGIS Pro 3.3.2 patch is available to download from My Esri as well as through the software update in Pro (if enabled).
To get the latest fixes, please install this patch. For a list of issues addressed you can review the Release Notes for ArcGIS Pro 3.3
Note: ArcGIS Pro 3.3 must be installed prior to installing the 3.3.2 patch. Patches are cumulative. When you install this patch, the issues addressed in a previously released patch are also included. It is not necessary to perform an incremental update of previous patches before installing this one. Here is additional information about Minor Releases and Patches
If you are updating from ArcGIS Pro 2.x to ArcGIS Pro 3.3.2, please review Migration from ArcGIS Pro 2.x to 3.x.
Comments
Bud
Legendary Contributor
Do I understand correctly that x.x.x patches normally only address issues, not add new functionality?
MarkMathews
This updated killed my program, opening clicking the button or opening the .exe from the /bin does nothing. Had to uninstall and reinstall at 3.3. The program will open again. Tried reinstalling the patch 3.3.2 and will not open.. Had to uninstall and reinstall again. Will not install the patch. Anyone else having this issue?
KoryKramer
Esri Esteemed Contributor
@Bud Yes, you understand correctly. Patches fix issues and do not add new functionality.
https://pro.arcgis.com/en/pro-app/latest/get-started/releases-and-patches.htm
ChrisMcGovern
We cannot get past Pro 3.3.0 either, as MarkMathews above also observed.
When Pro tries to download/install the program just terminates in process.
GISMapLady
Since downloading, I no longer have access to my excel files through ArcGIS Pro. I am now getting the error "Required Microsoft driver is not installed." My excel files worked fine in Pro before doing this latest update. @KoryKramer , do you have any suggestions? I have double-checked that I have all of the required drivers installed. Thanks.
Version history
Last update:
‎09-19-2024 11:06 AM
Updated by:
Contributors
