Receiving a "Error Opening Feature class the item doesn't have a definition.
9774
06-08-2020 12:39 PM
Christopher_P_Enright1
I am receiving a "Error Opening Feature class the item doesn't have a definition. Unable to instantiate class for xml schema type: LocationReferencingDatasetMembership" on our APR enable P_Centerline.
What causes this error? Also, I am only receiving it in ArcMAP & not ArcGIS Pro.
Tags (1)
AyanPalit
APR uses a 'controller dataset' for linear referencing and the Centerline layer is included once configured with APR. Controller dataset is specifc to ArcGIS Pro and hence you get the error in ArcMap. More info: Feature datasets in ArcGIS Pro—ArcGIS Help | Documentation
Ayan Palit | Principal Consultant Esri
AyanPalit
Thank Ayan. That was what I was suspecting but I couldn't find the documentation to confirm.
ModernElectric
@AyanPalit
I wanted to see if I could follow-up on this. I am running into the same issue. Created a feature class in ArcGIS PRO, however need to use the same FC in ArcMap. I understand ArcMap/ArcReader is considered "Obsolete" at this time. Is there a work around I can do?
Thank You
AyanPalit
@ModernElectric If you created a 'simple' feature class in ArcGIS Pro, it can be used in ArcMap just fine. The aforementioned issue comes into play when features participate in an LRS created using the APR extension. Some possible workarounds depending on your use case:
  • export the layers as simple features to a file GDB that is used for ArcMap
  • make a copy of the entire geodatabase and remove LRS for use with ArcMap
  • measures created in LRS should be retained when a copy is made
 Hope this helps!
