Help Entering Meets & Bound Call
729
10
07-09-2026 12:45 PM
Lebowski
Could someone please advise me on how to properly enter the highlighted call into the Traverse tool?
TimHodson
@Lebowski Since the first three courses reference the quarter section lines and don’t directly state any bearings, getting a “validated closure” for this deed description is not possible from my side. This is because the ¼ section lines will have direction differences and angle breaks that are not exactly 90 degrees, or 180 degrees, and they are not “exactly” north-south and “exactly” east-west.
So, the first three courses below are “made-up” by me using some best guesses, but those will need to be properly determined on your side based on your existing lines, your map projection, and so on.
However, that’s not your original question; the remaining courses after the first three show what to enter for the backsight angle mode.
Note that the angles as entered are only persisted for the life of the traverse in the UI, but the directions are computed from your entered angles and are stored on the lines.
S0-08-32E   2,682.55
S0-12-37W  34.32
N88-57-30E 1,369.52
+90-56-26  33.34
-90-56-10  1,465.18
+90-54-05  1,905.79
-135-9-54  26.43
+150-44-30  369.03
-177-08-56  321.46
-143-28-26 148.33
+116-14-03  136.9
+87-08-53  27.33
-75-50-30  1,370.48
+86-57-03  3,192.51
+90-21-25  1,500.34
