Copy Parallel Tool Not Working 3.7
370
7
4 weeks ago
Lebowski
Every since version 3.7 was released the copy parallel tool is not working with the Parcel Fabric (PF). I am receiving the attached error message.
Might anyone know what is causing this issue. Note the copy parallel tool works fine with non-PF data.
Thanks
ChrisUnderwood
Hello @Lebowski  , are you able to say if the problem still occurs with ArcGIS Pro 3.7.1 - available since yesterday ?
Lebowski
Yes, I just updated to 3.7.1 this morning and received the same error. @ChrisUnderwood
Rafael_Bombacini
@Lebowski Was this working for you in an earlier release? If so, do you remember which version?
Lebowski
@Rafael_Bombacini @ChrisUnderwood
I have another machine running version 3.6.2, the Copy Parallel tool worked correctly.
Rafael_Bombacini
@Lebowski I was able to reproduce the issue on my end. Could you please submit a support case with us using the link below?
https://support.esri.com/en-us/contact
Lebowski
@Rafael_Bombacini Thank you for verifying the issue. It looks like I don't have the appropriate authorization to create a support case. Could you please advise the best method to submitting the issue?
AmirBar-Maor
This issue is not specific to the parcel fabric. Any line feature with an attribute rule (validation) will fail.
The workaround is to remove the attribute rules from the line feature class, if that is possible.
If you have someone in your organization that has permission to submit a case please work with them. In fact, any customer that would like to see this fixed is encouraged to submit a case, which help prioritize fixing it.
