Update Parcel Features Tool to Enable Selection for Historic Features
1638
12-19-2024 09:23 AM
Status: Implemented
MizukiKayano2
Our organization makes heavy use of historic features, so much so that we do not separate it out into a separate layer in ArcGIS Pro, but have it shown directly with the active features (with different labeling). It’s quite common for us during a quality driven workflow to examine the historic parent parcel, what features make up that parent and make corrections.
Currently, when using the Parcel Features tool on an active parcel, it will return all the active lines, which functions as we would expect it to. However, the Parcel Features tool allows you to select a historic parcel, run the tool on it, and, as per the documentation, it only retrieves active lines, not historic lines.
The functionality we would like to see added would be that when the Parcel Features tool is run on a historic parcel, it selects the historic lines that are associated with the parcel first, and if there’s no historic line along part of the boundary, the active line that intersects the boundary is selected as part of the selection set.
When currently using the tool on a historic parcel, it will select the following lines (since they are active):
We would like to see it select all of the following lines (historic and active) – the first image is how we’d like to see it when historic and active lines are all in the same layer in Pro, the second image is how we’d like to see it when using the default view of the parcel fabric where historic features are separated from active features:
5 Comments
AmirBar-Maor
@MizukiKayano2
What is the expected behavior for points?
  1. Should it use the same logic? = Select the historic points first and then 'supplement' with current points?
  2. If we had a tool that filters and only shows historic features, would you expect current parcels to be selected as well?
  3. Can you explain why / when you would use the tool to select historic features?
MizukiKayano2
@AmirBar-Maor
  1. Yes
  2. No, I would only expect to see features with retiredbyrecord is not null
  3. During quality driven workflow, we would like to check/update the Calculated Area and Misclosure of a historic parcel. In ArcMap, "Parcel Details" provided this function. In ArcGIS Pro, Parcel Report (Utilities add-in) provides this feature, but when a historic parcel consists of active and historic lines, the loop cannot be formed. (screenshot below)
Active Parcel
Historic parcel
AmirBar-Maor
AmirBar-Maor
AmirBar-Maor
Implemented with ArcGIS Pro 3.7
