Why won't some popups work in a swipe map embedded into journal map?
1263
10-21-2016 03:29 PM
ThomasGelder
I've got a number of ESRI Story Maps composed of series of embedded Swipe Maps (example). On the right map, the popups for all the states west of Texas do not appear when you click on the state. If you zoom out two levels, you'll see that the popups for the west coast states start working. Alaska won't generate a popup until you zoom all the way out.
This issue does not occur on the swipe map only (here). The issue only crops up when the swipe map is embedded into a story map.
Is there any solution or workaround?
#story journal mapping application#swipe storymap
