Webmap layer filter by "contains"
10852
21
11-21-2018 08:01 PM
NaomiBegg2
I have a layer which is created in Survey123.  One of the questions is a select multiple type. On this question I want to create layer filters so that if it contains a certain text then it will appear in the layer.  The only options I can see is for it to be exactly one thing (or not or blank).
I have 6 different options within the multi type question.  That leads to 61 different selection combinations.  I was hoping that this tool would save me from having to create 61 different test surveys so that I can group them all which would look like (issues is a AND issues is b AND issues is c AND ...)
Is there any other way I can do this? Am I missing something obvious?
by Anonymous User
Not applicable
Thanks James, that did the trick.
NicolasGIS
Honored Contributor
Was the symbology a unique renderer based on that field ?
I am under the impression that "contains" is not available if the symbology is made on that field.
Too bad...
