Web map legend values do not update with Dynamic Range Adjustment
1325
05-22-2025 11:38 AM
NinaMauney3
I'm using Dynamic Range Adjustment (DRA) with stretch symbology (percent clip type) for a single-band raster layer in a web map. It's an imagery layer published as an image service via ArcGIS Server.
While the DRA appears to function visually in my web map, I've noticed that the legend does not update with the updated raster statistics for the new extent. When I change the display extent, the symbology updates to reflect values in the current extent - but the values displayed in the legend don't change to reflect the DRA.
Replicating this exact workflow (with the same dataset added from URL, symbology, etc.) in ArcGIS Pro yields a legend with values that update, so it does seem to be an AGOL-specific issue.
Is this a bug, or is there a setting that I'm missing somewhere in my AGOL symbology configuration?
JBH
I am also wondering about this.
NinaMauney3
I discussed this issue with ESRI support, and they documented it as a bug.
