Web Map Label Visibility Scale Range Not Working On Polygons
1899
04-02-2020 06:33 AM
by Anonymous User
Not applicable
I have a polygon of Fire District ISO ratings for the entire county.  My labels disappear if the user is zoomed in beyond the Buildings level.  No label at all.  I have played around with label size, arcade expression and turning off other labels to see if there is a conflict.  No matter what after the map is zoomed in beyond Buildings the labels disappear.  Has anyone else ran into this or know a workaround?
Here is the web map: http://arcg.is/PDC4G
AndyWells
I have this same problem with polygons. I can't remember a time when I didn't have problems with polygon labels when zoomed far in. I would love to see a solution.
CynthiaRoush1
I also have this problem. I need my viewers to be able to see the polygon label once they have searched for an address.
I believe the problem is that the label will not stray more than a certain distance from the center of the polygon. I can see the labels of smaller polygons at a closer zoom level, but still lose them when the center of the polygon is too far off the map.
