Web Map Filters no longer function properly with Feb 26 update
1123
6
02-26-2026 11:23 AM
TL2
The filter works as expected until I click apply, then the spatial disappears from the map.  The attribute table correctly reflects the filter.   Possibly only date filters.
Tags (1)
3 Solutions
KathrynWalker
Hi @TL2,
This is likely the same issue that is reported here: Re: Filter using "in the last" date no longer work... - Esri Community.
Please let us know if the behavior you are seeing is different.
Thank you!
Katie
Katie_Clark
MVP Regular Contributor
Maybe related to this bug? See this post:
https://community.esri.com/t5/arcgis-online-questions/filter-using-quot-in-the-last-quot-date-no-lon...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
RussRoberts
Esri Notable Contributor
This went out last night and the issue should be resolved now. Let me know if you see an issue. thanks!
KathrynWalker
Hi @TL2,
Thank you!
Katie
PeriGreen
I am having this problem currently but am not filtering dates. I am filtering a string of numbers (UserID) and it has disappeared and does not come back up. Unable to filter anything on my layer, even hosted layers that I previously filtered are no longer there. It is just blank
RussRoberts
If you can share the map/layer I can take a look.
Katie_Clark
Best,
Katie
RussRoberts
We are hoping have this issue patched tonight.
RussRoberts
