Web AppBuilder...have layers set to off
2949
03-21-2019 10:51 AM
Lebowski
Hello, everyone I using Web AppBuilder for the first time and I was wondering if there is a way to have the layers off by default?
I have several layers and I dont want them to all be on when a user first encounters the map.
Thanks
Tags (1)
RobertScheitlin__GISP
Chad,
   Initial layer visibility is controlled by the webmap that the app uses. So just turn off the layers in your webmap and voila.
SamButler2
Chad,
You also have the ability to create a layer list widget inside the Web App Builder so you have the ability to toggle layers on and off in the Web App. More information on the widget can be found here, I hope this helps!
sonia_ml
Is it possible to add the list widget to ArcGIS Experience Builder?
