Using geometry functions with Arcade in Map Viewer
1694
03-03-2022 08:19 PM
Labels (2)
explocarto
Hello,
I have a Point type hosted web service. I would like to use the functions of Geometries Arcade to display on my map buffers according to a conditionality.
Is it possible to achieve this?
I have gone through the official ESRI documentation as well as this forum. I can't find a solution to my question.
Can someone write a short sample Arcade code?
I can create a public web service as needed for support.
Thanks for your help
jcarlson
The short answer: no.
Arcade can do lots of things, but it cannot change the actual displayed geometry in your map, beyond simply determining the value of a feature for attribute-based symbology.
If you're looking to do that, the closest thing is a Hosted Map Image Layer, but that's only available in Portal, I believe. To get dynamically modified geometry onto the map will otherwise require your own custom coding in JS or something.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
explocarto
Thank you for your answer ! Have a nice day Josh !
